high compression vs. low
i know that low is good for turbos, just wanted to know if u will gain anything if u got low compression and no turbo, is it as good as high compression??
might sound confusing..
thanx
thanx
High compression means a more efficient burn, and more power/ torque. The reason you don't have higher compression ratios is becasue of the limitations of the fuel (it would detonate). It is lower on turbos than N/A because of that fact.
Higher compression with turbo makes one fast car..!!! But the problem is that it will be very difficult to tune. A low compression N/A is basically a econo-car. No point is going low comression unless you plan on FI.
gustavito1986
11
Dec 8, 2007 08:49 AM
