Hideous Nosie from tranny?
Old Jul 3, 2002 | 05:33 PM
quickLSt's Avatar
Default Hideous Nosie from tranny?
When I turn my car on (at idle) I hear some grinding/scraping noise. Also, when I shift gears, usually from 1st to 2nd and 2nd to 3rd I hear the same noise. Today, when I was driving home from work I was at a stop light and it sounded like something snapped or broke and my car hopped forward like it was about to stall.
What could be the problem? Tranny? Clutch? Thanks for the advise.
Old Jul 3, 2002 | 05:49 PM
Kamin's Avatar
Default Re: Hideous Nosie from tranny? (quickLSt)
sounds like a bent fork maybe? (in the transmission)
Old Jul 3, 2002 | 08:13 PM
AlphaKennyWun's Avatar
bad bearing?
Old Jul 4, 2002 | 11:00 AM
quickLSt's Avatar
Default Re: Hideous Nosie from tranny? (SO3Burner)
could this be a solution?
sounds like you're having the exact same problem as me. It may be your clutch master or slave cylinder. check to see if the master has fluid, if it's low, fill it up, take the cap off the slave cylinder and pump the clutch just like you would if you were bleeding brakes. once fluid comes out and you regain pressure in the clutch pedal, cap the slave cylinder and that should do it.
Old Jul 4, 2002 | 11:16 AM
LshatchTurbo's Avatar
New User
hmm if its clicking and sounds like its hitting something.. most likely its going to be a bent fork, or loose fork, or a messed up release bearing. All these would cause a clanking noise as you describe. Basicaly it sucks but should be looked at ASAP.
5speeder
Transmission & Drivetrain
Apr 28, 2012 09:38 AM
AZ-EJ1
Jun 16, 2007 02:49 PM
3.point.2
14
Apr 13, 2006 10:46 AM
snatchbakman
Oct 26, 2004 11:07 AM
quickLSt
Jul 6, 2002 04:03 AM
