hesitation / sputtering... help?!?!
ok so i have half a tank of gas left.. just starting doing this i drive the car it sputters / hesitate but rev up and its ok.. i put seafoam in the tank hoping it will clear any water or gunk out of the tank after the problem started.. pulled the plugs and they where more black then i have seen... where do i start?
what do you need to know to be a mechanic... is there a differance if i give you a motor code.. or what chassis its in... it still can happen to any car or motor theres not much more info you need..
00 civic hatch
B20z, B16a2 head
B16 trans
msd dizzy,wires, blaster coil,and 6al
p28 chrome
Jackson racing supercharger
Aem fpr
headers
40 psi fuel pressure at filter
cap, rotor, wires, plugs changed 2k ago
plugs changed again after this happened, old plugs where black.
started it up 10 mins ago it did finally show a cel its was 9 but not sure where the cylinder position sesnor is on the msd dizzy...
timing is dead nuts
B20z, B16a2 head
B16 trans
p28 chrome
Aem fpr
headers
timing is dead nuts
