Help! Wiring Continuity VSS/Speedometer/Odometer
Old Mar 12, 2007 | 10:56 PM
xpionage2's Avatar
Default Help! Wiring Continuity VSS/Speedometer/Odometer
Hi all,
I've searched for hours on the web trying to find out what the heck is going on with my speedometer and odometer. They are both malfunctioning - occasionally it'll work or bounce around like a kid on caffeine.
I originally thought it was my VSS that was defective, but I just had that replaced and it's not the problem. Thanks to honda-tech.com I managed to find several links and FAQ's about electrical.
So this is what I determined when I used my circuit continuity tester:
- the VSS connector has 3 wires, the blue/wht wire does not light up the tester
- the blue/wht wires that feed both speedometer and odometer at the cluster does not light the tester
- the blue/wht wire that detects the VSS at ECU DOES light up
Can anyone please help me pinpoint where I may find the loose or defective wiring? Is there a fuse box I can check? I tried following the blue/wht wire from the VSS connect but it branched into a bigger harness and goes into the abyss. Is it possible to follow that line all the way to the cluster?
ANY INPUT WILL BE GREATLY APPRECIATED.
Old Mar 13, 2007 | 04:10 AM
Ovrbst_T66's Avatar
Default Re: Help! Wiring Continuity VSS/Speedometer/Odometer (xpionage2)
check the vss plug its self for green corrosion*.make shur the pins are not a black color or green color (no good),if they are find a new one that is'nt corroded*.Cut the wires back and soldier in new one.when the pins are corroded* like that the wire is most likely corroded* too.If this checks out to be ok you might wanna try swaping out gauge cluster for known good one.
Old Mar 13, 2007 | 07:47 AM
xpionage2's Avatar
Default Re: Help! Wiring Continuity VSS/Speedometer/Odometer (Ovrbst_T66)
Thanks for the tip.
I will try to find a newer connector. In the meantime, please keep the ideas coming, people. Thanks.
Old Mar 13, 2007 | 12:21 PM
dinko's Avatar
My speedo worked before i pulled my motor
dropped the motor back in = speedo doesnt work
solution:
spray degreaser (i used greased lightning, you can use simple green) to get the corrosion out. i tried a bunch of diff stuff...i let it soak...kept spraying it in there until i thought i got most of it.
then i took brake kleen and kept spraying that in there so the connector wouldn't become sticky from the degreaser. after it dries up i plugged it back in...and it worked..
(prior to this i had also tried a different VSS and no luck)
Old Mar 13, 2007 | 02:40 PM
DeadVet's Avatar
Default Re: Help! Wiring Continuity VSS/Speedometer/Odometer (dinko)
If the odometer and speedometer both go nuts at times chances are your cluster is going south.
Old Mar 13, 2007 | 04:23 PM
xpionage2's Avatar
So I just checked my VSS connector and it looks immaculate, considering how old the car is. The connectors are still bright silver with no signs of corrosion.
I need to find someone that will lend me a cluster to check out. I'm not in the position to buy another and find out that it's not the problem.
I really appreciate the feedback guys.
Old Mar 14, 2007 | 01:52 PM
dinko's Avatar
Default Re: (xpionage2)
Check all your grounds first, especially the one by the thermostat...
Old Mar 14, 2007 | 02:56 PM
xpionage2's Avatar
Default Re: (dinko)
Where is the thermostat located? If that was faulty, wouldn't that affect other electrical components?
Old Mar 14, 2007 | 08:43 PM
xpionage2's Avatar
Hey guys, I fixed the problem. I found someone that was selling a cluster that was only 1K (km) more than mine. The problem is fixed!
I can't believe that was all it took.
Thanks for all your help. Now I have an extra VSS - anyone need one? =D
new_kid
Feb 8, 2009 03:07 PM
^Sammy]!.
Feb 12, 2005 09:53 PM
I8ayellowcrayon
May 24, 2004 08:21 PM
SleepnCiViC
13
Dec 11, 2003 02:59 PM
CTRwannaB
Dec 6, 2003 04:52 PM
