Help with weird MIL buisness...
93 VX hatch with a 94 GSR engine in it. I checked the MIL code and it was an infinite number of longs... i waited til 23 longs then quite watching. Anyone know what that means? Thanks
-Nick-
-Nick-
so an infinite number of shorts would be code 1?
Also this code only gets thrown when the car is driven hard and after about 10 minutes of hard driving. If you just cruise, it wont throw anything.
-Nick-
[Modified by B19CivicHB, 11:36 PM 8/29/2002]
-Nick-
Guest
Posts: n/a
Nick,
Are you sure you're not just missing the pause between codes? I know that has happened to me many times. After staring at the dam check engine light blink and blink, I miss a blink or a pause, and I think it's something it isn't.
Code 10 is the IAT, if you have another, try it, and then go from there. Also, check your wiring, and make sure there's not a bad connection. A loose wire, or a corroded one can cause the ECM to toss a code.
Good luck!
Good luck!
