Help W/ a head
Old Mar 30, 2005 | 02:46 PM
LSEGHATCH's Avatar
Default Help W/ a head
I noticed today that my b16 head doesn't have all of the "prongs" for both the exhaust and intake manifold to bolt up to. Is it just me or is something wrong here? If it's just me and you can buy these (someone help give them a name), how do you get them in and where can I pick some up? I hope the threads aren't stripped.
Thanks
Old Mar 30, 2005 | 02:54 PM
PrettyLude's Avatar
try and get it used from another motor or arp sells them
to put them on use the double nut method
Old Mar 30, 2005 | 02:55 PM
LSEGHATCH's Avatar
Default Re: (PrettyLude)
More on this "double nut" method please?!
Old Mar 30, 2005 | 03:40 PM
NJIN BUILDR's Avatar
Default Re: (LSEGHATCH)
They are called intake studs or exhaust studs.Part #21 and #26. http://www.hondaautomotivepart...EC%29
Glenn
Old Mar 30, 2005 | 03:42 PM
jweller's Avatar
just take one nut, screw it down part the way onto the stud. then take a 2nd nut and tighten it down against the 1st one. then you can just use a wrench or a socket on the stud.
Old Mar 30, 2005 | 03:52 PM
LSEGHATCH's Avatar
Default Re: (jweller)
Thanks, but how tight to I go on the stud? I don't wanna mess up and end up having to re-tap the hole.
Old Mar 30, 2005 | 04:04 PM
PupaScoopa's Avatar
I took all of my studs out and used some purdy 8mm 9-grade flange bolts. Looks good, works great!
Old Mar 30, 2005 | 04:13 PM
LSEGHATCH's Avatar
Default Re: (PupaScoopa)
Any pics?
Old Mar 31, 2005 | 05:12 AM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSEGHATCH &raquo;</TD></TR><TR><TD CLASS="quote">Thanks, but how tight to I go on the stud? I don't wanna mess up and end up having to re-tap the hole.</TD></TR></TABLE>
it will stop itself on the stud, once you see no more teeth on the inside of the stud, you should stop
Old Mar 31, 2005 | 06:07 PM
LSEGHATCH's Avatar
Default Re: Help W/ a head (LSEGHATCH)
I checked out ARP's website and found the studs but they don't list Honda's. Where to look now?
Old Mar 31, 2005 | 07:41 PM
PrettyLude's Avatar
try calling them, and see what they say
Old Mar 31, 2005 | 07:59 PM
Dragline's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSEGHATCH &raquo;</TD></TR><TR><TD CLASS="quote">I checked out ARP's website and found the studs but they don't list Honda's. Where to look now?</TD></TR></TABLE>
ARP part#400-8032 pack of 16 1.5" long
ARP part#400-8033 pack of 16 1.75" long
Take your pic.
Old Apr 1, 2005 | 08:24 AM
LSEGHATCH's Avatar
Default Re: Help W/ a head (dragline)
Thanks guys.....
Corksil
Feb 2, 2011 01:21 PM
eurocrx
Oct 24, 2010 11:06 AM
GsR92HaTcH
Aug 26, 2006 11:28 AM
99EletronblueSI
Oct 16, 2004 08:25 PM
