Help with transmission that won't stop leaking
Old Mar 13, 2007 | 12:01 PM
frontwheelfanatic's Avatar
Default Help with transmission that won't stop leaking
my transmission won't stop leaking, i've changed the fluid 3 times in the last 9 days. its leaking from the drain plug, but only while being driven. i've used a new crush washer every time and torqued it down to spec, but still it keeps leaking. and its not like a slow leak, after a drive around for like a mile you could see the fluid dripping from the drain plug, and you could see the splatter on the control arm and sway bar. i've had it, i don't know what else to do, the last time i even tried hondabonding the drain plug, but it sill leaked? PLEASE HELP! the tranny is a 95 gsr if that helps any
Old Mar 13, 2007 | 01:14 PM
Default Re: Help with transmission that won't stop leaking (frontwheelfanatic)
please i can't stand my transmsission being this way anymore
Old Mar 13, 2007 | 02:31 PM
DeadVet's Avatar
Maybe try a new bolt and if its not that then check closely for cracks in the tranny that could be leaking.
Old Mar 13, 2007 | 03:55 PM
Default Re: Help with transmission that won't stop leaking (1TurboHatch)
new bolt is on order from honda should be here tomorow. no cracks in casing. problem occurred after i changed the tranny fluid for the first time. i'm just trying to get everyone elses opinion cuz i'm ready to lose my mind
Old Mar 13, 2007 | 05:59 PM
96Spec Ek's Avatar
Try putting some teflon tape on the threads
Old Mar 13, 2007 | 06:03 PM
Default Re: Help with transmission that won't stop leaking (96Spec Ek)
i did the hondabond and teflon tape on sunday and it was still leaking. is there anything else in that general area tha could be leaking transmission fluid?
Old Mar 15, 2007 | 04:30 PM
rdeezy78's Avatar
only thing I can think of is maybe you messed up a couple of the threads on the plug. Hope not, but if so, hope it mess up the threads in tranny. Good luck
Old Mar 17, 2007 | 11:14 PM
Default Re: Help with transmission that won't stop leaking (rdeezy78)
it was the transmission seal
UrbanEh
Jun 21, 2007 02:08 PM
frontwheelfanatic
Mar 16, 2007 09:18 PM
Ants
Mar 18, 2004 06:27 PM
The Internet Tough Guy
Nov 1, 2003 12:37 PM
tweekerz
May 9, 2002 11:22 AM
