help on timing
i have a jdm gsr block wit a type oil pump and was wonder which lower timing belt cover to use obdII or obdI...cause i have heard something about if u are using a itr oil pump u need to use a obdII lower timing belt cover becuase of how the lower timing belt cover is shaped...so which one do i use...obdII or obdI????
boosted k20
Oct 16, 2017 11:11 PM
