Help with swap?
Old Nov 29, 2008 | 06:56 PM
medicalsurfer's Avatar
Default Help with swap?
I have a 98 ex with a d16y8 motor, and the vtec head was replaced with a non vtec head. so what all do i need to swap it back. will i need a new wiring harness, ecu, ect.....??? Thanks, any advise is great. Thanks again.
Old Nov 30, 2008 | 02:06 PM
JDM94HATCH's Avatar
First off u would need a z6 or a y8 vtec head . New head studs,head gaset, while ur add it u might as well pick up up a new timing belt , water pump , tensior if ur running the stock ex harness ull be mint on the wiring . do u kno what ecu u have ?? if u have a p2p ECU again ull be mint
Old Nov 30, 2008 | 02:46 PM
ISawUL00k's Avatar
make sure the oli feed line in the block is clear. sometimes there is crud there.. im assuming u have a complete head....otherewise make sure ur harness is an ex..!! to check look for a green plug near the diz.
muhaMan
10
Feb 5, 2007 11:32 PM
Hatchdude
Jun 30, 2005 01:37 PM
simplypinoyy
Jan 7, 2004 02:54 PM
Accord_Kid
Oct 11, 2003 07:08 PM
Civiclx
Aug 1, 2003 06:24 PM
