HELP!! Stumped! Hesitation issue when accelerating.
Old Aug 27, 2014 | 07:32 AM
  #51
gearhead2228's Avatar
Default Re: HELP!! Stumped! Hesitation issue when accelerating.
Originally Posted by gearhead2228
I gotchya so the o2 sensor is probably shot. But what i don't really get is why the car runs better and there's no cel without the o2 sensor plugged in?
Thanks for your response, I had mentioned it a little while back. It was running better with the o2 sensor unplugged so I replaced it with a brand new Denso one. Seems to have a helped a little but definitely didn't fix the problem.
I thought maybe it was the egr as well but did some research and looking around the engine and it turns out the zc's don't have them. So that was a dead end.
I really feel like it's the coolant temp sensor, because of the hesitation only at operating temp and because when it's cold it'll turn over quite a few times before it fires up. Which are both signs of a bad ect right?.... are the values I measured and listed earlier far enough off that it would cause these problems?
Old Aug 27, 2014 | 11:23 AM
  #52
holmesnmanny's Avatar
No they seem fine but like i said test it again with the mm on more accurate settings if you want.
Old Aug 27, 2014 | 12:22 PM
  #53
M3THTICAL(EF)'s Avatar
I remember my d16a6 had the same problem. It went away with a full tuneup (plugs, wires, o2 sensor, fuel filter, cap and rotor, plus the fuel injector cleaner). Maybe your injectors are really clogged up!
Old Aug 27, 2014 | 02:37 PM
  #54
Thanks for the responses guys. Alright I'll definitely test them both again and try to get a more accurate reading.
And yah that's a definite possibility, I hope that's not it because getting new injectors/getting them professionally cleaned is expensive out here in new mexico.
I've pretty much done the full tune up, fuel filter, o2 sensor, new plugs/wires. The only thing I haven't done is the cap and rotor. I'll probably just end up getting a whole new distributor instead though, because the one that's on there now is kind of Frankensteined lol. When I did the swap I just took the internals from a new distributor and put them in the td-03u case.
Old Aug 27, 2014 | 10:42 PM
  #55
Don't know if it's a related symptom or part of the cause, but driving today I noticed a pretty heavy gas smell. I think it was most likely coming from the exhaust fumes. Needless to say i think the car is running really rich. Also I went back and looked at my old o2 sensor that i changed a few weeks ago and it was pretty black, which pretty much confirms it.
Another thing I noticed, that while driving at night having my lights on makes the hesitation problem quite a bit worse......
Old Aug 28, 2014 | 07:17 AM
  #56
mike_1212's Avatar
Check for a bad connection and definatly loose pins on the connecter for the tps.
ghettoda9
Dec 28, 2011 04:59 PM
Wopsicle69
Dec 18, 2004 10:20 AM
Wraith
Oct 9, 2004 02:12 PM
91DroppedHatch
Aug 21, 2004 08:20 PM
Erik_Pb_Foot
Aug 23, 2002 07:21 AM
