HELP with sparco installation
Old Aug 4, 2003 | 06:18 PM
civic_tko's Avatar
Default HELP with sparco installation
hi im having a hard time assembling my sparco sliders to my sparco brackets... ive searched on the internet for instructions but cant seem to find any... it seems somewhat self-explanatory until i realize that i cant seem to get any of the holes to line up correctly... any help would be appreciated thank you
Old Aug 4, 2003 | 09:32 PM
StreetMod's Avatar
Default Re: HELP with sparco installation (civic_tko)
I had to refab the back mounts on my Sparco brackets as they did not line up with the hole in the floor at all! I did not have any problems with the mounting of the sliders to the brackets though. Wish I could offer more assistance.
Old Aug 4, 2003 | 10:29 PM
civic_tko's Avatar
Default Re: HELP with sparco installation (The Sheriff)
Did you buy the universal floor mounts, or were they model-specific to your car? Either way, my sliders don't seem to line up with my brackets. Well let me back up a second. First I should say that I'm not completely sure how to mount the slider to the bracket, before going off saying they don't line up. Now with that said, I am doing what most obviously seems correct. Should the two brackets (one on each end of the slider) with the three holes in it be pointing up, towards the top of the car, or down, toward the floor?
Old Aug 5, 2003 | 09:02 PM
civic_tko's Avatar
Anyone? Anything... a diagram, a picture... pppplllllleeeeeaaaaaaaassssssssseeeee
Old Aug 6, 2003 | 03:53 PM
StreetMod's Avatar
I cant figure out what you are describing by your explanation.............I dont have any way of posting a pic or I would.
One half of the slider should be smooth with holes in it and the other half will be raised up in the center with the mounting holes(looks like a strip has been welded on). The smooth flat surface goes down(mounts to the bracket) and the other(with the welded piece) to the seat.
You might have the incorrect hardware cuz I didnt have any troubles except for mounting the bracket to the floor.
Old Aug 6, 2003 | 06:34 PM
civic_tko's Avatar
Alright well I follow you so far... I now know which side goes up and which goes down. However, I don't understand how the slider bolts to the bracket now. [img]C:\Brian\crappy diagram.bmp[/img] This is a crappy diagram I drew real quick... any help?
Old Aug 7, 2003 | 06:39 PM
StreetMod's Avatar
Your diagram is a "red x". Anyway, you should bolt the slider to the seat first and then slide the slider forward and backward to expose the holes on the end and put the bolts in .
Old Aug 7, 2003 | 09:49 PM
civic_tko's Avatar
ah im sorry. i wasnt thinking and tried to host the picture from my computer. its not worth posting anyway, its too crappy. i think i see what youre talking about now. if i have any further questions ill post them. thanks.
Old Aug 7, 2003 | 10:05 PM
civic_tko's Avatar
ah ha! i found the culprit... everything is solved. the problem was... i bought the sliders off of ebay. the description "claimed" they were new, but they obviously werent. the guy who had them before me attached a piece to the bottom of the sliders... probably some sort of custom fabrication for what he needed them for. the holes that you were describing that attach to the bracket are filled with a nut and bolt to hold his extra piece on. i did not realize this because i assumed that added piece was in fact part of the slider. but after examining the picture on the sparco website, i realized that the added piece is not supposed to be there. taking it off will free up the holes to attach to the brackets. thanks everyone.
sohcrx91331
Oct 18, 2010 11:41 AM
GR_DC2
Oct 12, 2005 06:14 PM
RineRacing
12
Nov 1, 2002 08:23 AM
ShowSpeed
Oct 10, 2002 07:32 PM
RineRacing
Jul 17, 2002 11:19 AM
