Help some help here
Old Jul 15, 2016 | 06:12 AM
EJ8CIVIC's Avatar
Default Help some help here
96 civic temp gauge creeps up hot when i drive with the ac on when i come to a stop..
New thermostat, no leaks, runs strong
I cant pin point the issue
Old Jul 15, 2016 | 09:01 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Help some help here
Is thermostat OEM or aftermarket?
New Thermostat means you've cracked open the cooling system, the other thing to do is rebleed the system of air. You probably still have an air pocket in there.
If not OEM thermostat, go buy one from Honda as aftermarket thermostats are notorious for causing problems. Thermostat is one thing you always do OEM.
Old Jul 15, 2016 | 09:18 AM
EJ8CIVIC's Avatar
Its autozone oe spec.. Iv never had issues with them ill rebleed the system today..
Recap my knowledfe of rebleeding
Take cap off, let idle with heater on full blast until i see no more bubbles and fill as i go?
Old Jul 15, 2016 | 03:42 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
96 doesn't have the bleeder screw of the 5th gen (92-95) so you normally lift the front end a little or park with the nose pointed up on an incline. Unscrew cap to loosest setting that doesn't actually come off. Top up reservoir (probably easier to do before you raise the front end or park on an incline), then start her up and wait until the fan kicks on at least twice.
Usually this is done from a cold engine so can take over 20 minutes.
I personally wait until the fan kicks on 3 times.
After that, turn the car off, remove cap and top up radiator. Put cap on and close totally. Next morning/day top up reservoir and you should be good.
Old Jul 15, 2016 | 06:35 PM
EJ8CIVIC's Avatar
Thanks for the info.. I will do that.
B_Swapped93
Jun 7, 2014 03:53 PM
theputz
15
Nov 20, 2009 06:38 AM
EddieLe76
Nov 19, 2008 11:03 PM
S@nt0s
12
Feb 25, 2004 05:16 PM
