HELP!! SMOKE???
Old Nov 2, 2003 | 04:18 AM
DANG YO's Avatar
Default HELP!! SMOKE???
ok today i was driving my car in front of my friend. he told me everytime i got on the gas hard my car smoked blackish white and when i let off the gas to change gears thats when he said it smoked the most. i was thinking it is running rich and it was cold lastnight so it maybe steam too, also when i disconnected my PCV valve hose from my valve cover, when i reved the gas a little a little bit of smoke came outta the hole in the valve cover.... what could be the problems? also i changed my spark plugs like 2 weeks ago and they still look brand new, is that good or bad? by the way it is a b16a in my crx with mild mods........ thanks for any help given
Old Nov 2, 2003 | 06:10 AM
DVS_EF's Avatar
Default Re: HELP!! SMOKE??? (SiR EF8)
it's probably your piston rings, or valve seals that gone bad... do a compression test to find out... hope this helps
Old Nov 3, 2003 | 05:02 PM
CleenSi
Guest
Posts: n/a
Default Re: HELP!! SMOKE??? (dvsEF)
try messing with yer ignition timing, i changed mine n it all worked out.
good luck
Jennperry32
Apr 16, 2013 07:55 AM
DVPTeG
Jun 4, 2007 11:51 AM
killingtwobirds
Apr 4, 2007 04:50 PM
Ls-Turbo
Dec 11, 2005 10:30 AM
Diego Boost
Jan 6, 2003 01:28 PM
