HELP rubbing/buzzing noise from rear of car
so i just noticed the other day that at speeds above like say 25mph im getting a constant buzzing/humming/rubbing noise coming from my passenger rear tire. almost sounds like i have an exhaust but i don't or like a piece of plastic is rubbing the tire, but there is nothing. the noise will get louder when speed is increased and when i turn and take the weight off the passenger side it stops. car is lowered with ground control and koni's if that matters. i need help soon tho the 4 hr drive i have again tomorrow is gonna be mind numbing. thanks
Sounds like wheel bearing. Try driving car at highway speeds for a few miles. Then take a portable Mac temp gun and measure hub temps on back. If the side making noise is hotter, you need a new wheel bearing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IndySporty »</TD></TR><TR><TD CLASS="quote">Sounds like wheel bearing. Try driving car at highway speeds for a few miles. Then take a portable Mac temp gun and measure hub temps on back. If the side making noise is hotter, you need a new wheel bearing.</TD></TR></TABLE>
Or you can just rock the wheel and see if there is play.
Could also be that your drums need a bit of adjustment or cleaning.
Maybe you ran over a piece of debris and it go wrapped up in there. Have a look see.
PinoyCivic
Jan 11, 2006 06:11 AM
