HELP!!!! RPM CLUSTER ISSUE
Old Jan 27, 2007 | 07:10 AM
texas_tea_2k6's Avatar
Default HELP!!!! RPM CLUSTER ISSUE
TRYING TO CONVERT FROM CLUSTER W/O RPM METER TO CLUSTER W/ METER
I HAVE 94 CIVIC DX COUPE, THE CLUSTER DOES NOT HAVE AN RPM METER. I KNOW I CAN GET A CLUSTER FROM A DIFFERENT CIVIC WITH THE RPM METER. POINT IN CASE I WANT TO KNOW IF THERE IS ANYTHING ELSE IM GOING TO NEED AND FAR AS CONNECTORS ETC. IF U DONT UNDERSTAND PLEASE REPLY BACK AND ILL MAKE CRAP MUCH EASIER TO UNDERSTAND. PEACE
I WANT 2 KNOW EVERTHING...... WHAT ISSUES WILL I RUN INTO? WHATS THE DIFFICULTY? WILL IT EVEN WORK CORRECTLY?
Modified by texas_tea_2k6 at 8:23 AM 1/27/2007
Old Jan 27, 2007 | 03:11 PM
gibsanez's Avatar
Default Re: HELP!!!! RPM CLUSTER ISSUE (texas_tea_2k6)
Plz turn off caps.
Get a cluster from any 92-95 civic with a tach. Your current plugs should be the exact same. The only shitty part i can say about the cluster swap in a 5th gen (compared to a 4th gen) is you have to pull like half of your dash off just to get at the bugger, compared to 4 screws on the cluster hood of a 4th gen.
Old Jan 27, 2007 | 08:42 PM
Default Re: HELP!!!! RPM CLUSTER ISSUE (gibsanez)
Thanks alot bro, i think it was kind of a dumb question cuz i figured i could do it, guess i just wasnt to so sure. I hope all turn out well when i get it out etc.
tamadrummer1120
May 27, 2016 11:27 AM
4drctr420
Honda Civic (2001 - 2005)
Aug 1, 2011 05:00 AM
4everjdm
Nov 22, 2010 09:07 PM
thisboyjulio
Sep 5, 2007 05:42 PM
CIVIC dude
Aug 1, 2003 03:06 PM
