help quick. idleling sporratically after coolant flush.
Old May 14, 2004 | 06:33 PM
civboy115's Avatar
Default help quick. idleling sporratically after coolant flush.
we just flushed the coolant in a 95 del sol and after a test drive the car idled wierd from 1k to 2k. it just jumped between the two. We had the resevoir filled with coolant but put alittle too much in, so we filled the radiator with water, or half way...we really cant tell, and when it sits ideling, it jumps from 1k to 2k. Is this just becuase the coolant needs to circulate through the motor or what?
any help would be great thanks.
Old May 14, 2004 | 06:37 PM
civboy115's Avatar
Default Re: help quick. idleling sporratically after coolant flush. (civboy115)
bump please help
Old May 14, 2004 | 07:10 PM
kazx7r's Avatar
recheck your coolant level, you probably had an air pocket in your coolant system. Chances are it's low. Make sure you check the level in the radiator. Good luck.
Old May 14, 2004 | 07:18 PM
blkwidow420's Avatar
Default Re: help quick. idleling sporratically after coolant flush. (kazx7r)
He's right you have air in the system check your level and see if it's low.
Also could thy running it (from cold) with the radiator cap off
Old May 15, 2004 | 12:56 AM
hondatechnician's Avatar
Default Re: help quick. idleling sporratically after coolant flush. (blkwidow420)
if its a b-series engine dont take the cap off that wont help theres a bleeder screw for ur coolant on one ur hoses
91civicsikid
13
Jun 24, 2014 03:23 PM
2000eK_cIvIc
13
Apr 19, 2011 05:04 PM
CDtegGo
Aug 27, 2006 02:22 PM
mikeyp5d
Jul 24, 2005 07:42 PM
Accorddrver
Jun 29, 2004 06:25 PM
