HELP PLEASE My car is Freaking - fuel problem
Old May 29, 2002 | 09:14 PM
kamira's Avatar
Default HELP PLEASE My car is Freaking - fuel problem
hey everyone.
My car is bogging like no business. Its a B16 in a CRX. Heres the reason i think its bogging. The fuel pressure is reading out at 60psi idle and 65 psi hitting gas. Well I cant bring it down on my AEM FPR. I have the on the rail model, Used it for many months with no problems. Now i have the screw backed all the way off where it is basically comming out the damn fpr and i cant get lower then 60. I can get it higher though. I think the reason im bogging though is because the injectors arent liking this high *** pressure. Any ideas of whats up. I was thinking my return line was clogged or something but thats unlikley. I tried everything to lower it, it wasnt having it. When i even opened my gas tank (88 crx) it make a weak PIST noise for releaving pressure and the rail still read 45 psi. ANY IDEAS?>
Old May 29, 2002 | 10:49 PM
Dutchie's Avatar
Default Re: HELP PLEASE My car is Freaking - fuel problem (kamira)
Is the AEM like the B&M where you have to cut the stock FPR? If it is you possibly cut too much off the top. If not, I would try swapping the stocker back on. Do you have an aftermarket fuel pump?
Old May 30, 2002 | 10:08 AM
kamira's Avatar
Default Re: HELP PLEASE My car is Freaking - fuel problem (Dutchie)
no its a full replacement unit built to work on the rail.
hyabusa hunter
Jun 7, 2007 12:55 PM
civicsit
Sep 12, 2006 01:21 PM
jdkornlp
Aug 18, 2005 02:34 PM
ATS*Mark
Jul 20, 2004 06:16 AM
B18B1DOHC
Dec 23, 2003 10:48 AM
