Help: OEM FOG LIGHT INSTALL
I've just purchased a used set of OEM USDM fog lights for a DC2 integra. Does anybody know how to install these in respects to cutting the grill, where they bolt to and wiring to the oem switch?
Thanks for all your help.
Never installed a set on an integra, but if they are anything like a civic then i could help. If its an OEM bumper there should be markings on the back of where to cut. The civic had dots and i just connected them with a ruler, then dremeled it out. As far as the wiring goes, im not sure f the car is pre-wired like mine was. hope that helps
Don't you have the instructions? Is it a '98+ Integra and foglight kit?
Instructions for installation of '98-'01 Integra OEM Raybrid Foglight Kit in Word format:
http://portfolio.iu.edu/bchang...2.doc
What year? I've got '95 instructions, I can email you if yours is '94-96? or whenever they changed the grille...
Use a box cutter or x-acto knife to cut out the lower-outboard section of the grille. There wasn't really any lines, you just remove the blank flat section & leave the upright painted rib.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC »</TD></TR><TR><TD CLASS="quote">Don't you have the instructions? Is it a '98+ Integra and foglight kit?
http://portfolio.iu.edu/bchang...2.doc</TD></TR></TABLE>
The link only gives me the parts page, is there a link to the rest. I got the kit used so there were no instructions. Thanks for your help so far but is there a way to get the rest of the pages?
