Help me! What throttle body is this?
What throttle body is this? Where does the map sensor suppose to go? I know it suppose to go to the top left but with this i dont have a clue.
i dont know what kind of TB that is but for map sensor wut i did was connect a vac hose to the map sensor and the TB theres a thing sticking out that a vac hose would fit
Its either an LS or a D series tb. The older LS has the colant reservoir like the on you showd in the picture and as well as D series. Also if you look there are two holes besides the butterfly (ls has those too) and if the Map sensor is not connected on the tb its and OBD0 tb, dont qoute me I might be wrong!
its an early TB from 93 down integras, first gen b16, and early civic crx. U can tell by how the map sensor would mount. It has a nipple where u hook up a vacuum hose to and run it to the map sensor where it is usually mounted some where on the firewall.
EgSalad
Jun 6, 2007 12:12 PM
KevronsEG
Jan 31, 2002 05:23 PM
