help me out
Old Apr 23, 2007 | 04:12 PM
tbuck23's Avatar
Default help me out
ok here the problem when i go to start my car it will not start. But when put the gas padle down to the floor she start, but when i go to stop the car she died what the problem. it's a 94 honda civic dx
Old Apr 23, 2007 | 04:17 PM
D16Cowboy's Avatar
Default Re: help me out (tbuck23)
What is the lowest possible RPM you can run the motor before it cuts off?
Old Apr 23, 2007 | 04:21 PM
tbuck23's Avatar
Default Re: help me out (D16Cowboy)
yea it run if hold the gas padle down, the rpm start a 1000
Old Apr 23, 2007 | 04:24 PM
D16Cowboy's Avatar
might be an idle issue... but does the motor try to run below 1000 or does it remain steady at 1000? Try increasing your idle.
Old Apr 23, 2007 | 04:30 PM
tbuck23's Avatar
how can i do that, and + when the car is run only two only my hearder are hot but 1-4 are not could it be my Fuel Injectors are mess up
Old Apr 23, 2007 | 04:39 PM
D16Cowboy's Avatar
Default Re: (tbuck23)
It sounds like you just said your 1 and 4 cylinders are not firing? How did you determine that? I'm having trouble understanding you.
Old Apr 23, 2007 | 04:45 PM
tbuck23's Avatar
ya we thing 1 and 4 are not firing and how determine that is but touch the header are not hot .
Old Apr 23, 2007 | 05:08 PM
tbuck23's Avatar
i think my Distributor Cap, Rotor need to be change
Spawne32
Jul 9, 2011 05:08 AM
chrisfromsrq
Jul 21, 2009 08:41 AM
teg racer 877
May 23, 2006 08:03 PM
dubracr18t
Aug 25, 2003 08:08 AM
