help me diagnose this
Old Oct 10, 2004 | 06:53 PM
1slohatch's Avatar
Default help me diagnose this
b16a obd-0: Whenever im acclerating and then, diengage clutch and let off the throttle completly the car will backfire slightly as the engine winds down below 1000 rpm or so. Also whenever I turn the engine off it sounds like it blows air out of the intake maybe 2seconds after i turn the key off. put put... poof. Not noticing any other symptoms, car idles fine acclerates fine. Things i've tries so far. New spark plugs, igniton timing adjustment. Also I just recently installed a VAFC, but I dont have it set to scale the map signal at all.
Old Oct 10, 2004 | 07:11 PM
Kamin's Avatar
Default Re: help me diagnose this (1slohatch)
the second problem is totally normal because the engine dosent turn off as fast as you can turn the key off, the monentum carries it for another couple revolutions.
the first one is way too vauge and makes no sense to me.
Old Oct 10, 2004 | 07:50 PM
Bandit74's Avatar
I was going to suggest the timing is off with that backfire, but...
zenney
Feb 23, 2010 12:26 AM
:::SIRll_EJ1:::
Feb 6, 2010 12:55 PM
zeplin
Jan 26, 2009 12:08 PM
SoHc94
22
Aug 26, 2006 09:18 PM
gen2teggy
Apr 8, 2006 09:21 AM
