help...leaning out after vtec itr powered hatch
Old Jul 29, 2003 | 12:20 AM
WCI's Avatar
WCI
Default help...leaning out after vtec itr powered hatch
have been running the old b16 computer and just got my itr computer today. put it in and it is pulling harder but it seams to lean out on my a/f guage after it hits vtec (set at 5400 vafc) any suggestions. I was thinkin that I might need to upgrade the fuel pump to gsr or itr. also I was wondering what all of you are are setting you vafc hi and low throttles at. Want to get this settled before wednesday so I can run her at the track-thanks
Old Jul 29, 2003 | 12:34 AM
WCI's Avatar
WCI
Default Re: help...leaning out after vtec itr powered hatch (WCI)
also does anyone know if the timing belt cover on the b16 is the same as the itr. didnt have a cover so ripped the cover of my b16a2 and used that to time it.
Old Jul 29, 2003 | 03:30 AM
7PSiEF9ZC's Avatar
I belive they are the same. I don't think the GS-R's aren't cause they are alittle bit taller motors then the B16 so I'm not 100% sure but I believe it may fit.
Old Jul 29, 2003 | 07:59 AM
preluder's Avatar
Default Re: help...leaning out after vtec itr powered hatch (7PSiEF9ZC)
its always good to upgrade I did mine myself dropped the whole tank and all. upgrade it anyway If your juicin or boostin.
Old Jul 29, 2003 | 03:42 PM
.xcalibur.'s Avatar
The pump may be the problem. Also the vtec unmatched values on the vafc must be changed as well. You cannot just move vtec to a different point and expect everything to be smooth. Vtec will be at a different point, but it wiill not be running the correct fuel maps needed to run properly. Without a good tuner, the vafc is just good for its visuals.
Old Jul 29, 2003 | 03:45 PM
quik1's Avatar
Default Re: help...leaning out after vtec itr powered hatch (.xcalibur.)
I had the same problem I put in a holly pump and it solved that problem.
Old Jul 30, 2003 | 06:24 AM
WCI's Avatar
WCI
Default Re: help...leaning out after vtec itr powered hatch (quik1)
ok thanks guys. think I will change the fuel pump
Bxaffiliant
Jun 6, 2005 07:59 PM
red_ek_hatch
Apr 4, 2005 05:28 PM
red_ek_hatch
Apr 4, 2005 05:26 PM
NeXtLeVeL_TyPe_R
Nov 13, 2001 04:05 PM
