help with h22 acura cl
ok heres my problems...
car runs sluggish when timing is set correctly and the knock sensor cel comes on after about 45 seconds. So i have it advanced pretty far, as a result, the car idles at about 2300-2500 rpm. AND when i am driving, if I stop the car and then start it again it will run horrible. Very bad hesitation when at part throttle and the idle drops to about 1200-1500 rpms, but if i turn the car off and back on again quickly it will start working good again. Very weird. any help would be great.
Modified by lcaruca97 at 11:01 AM 10/1/2003
My buddy did a swap and had horrific problems until he bought the wiring harness for the swap. Stupid cheap bastard! He even put in a 5spd. All is well now that it's wired right which is also what sounds like the problem above.
JDM-CD5H22
Oct 18, 2007 03:22 PM
1point7db2
Sep 22, 2004 03:24 PM
