Help with fuel system problem
Old Jul 5, 2003 | 12:56 PM
delSolLS's Avatar
Default Help with fuel system problem
I have a built 95 B18B and am trying to track down a fuel system problem. Low idle, dies upon coming to a stop. Sometimes at initial start up, it misses. Car was showing CEL codes 41 & 43. I have had trouble with the 02 sensor in the past and just put in a new sensor from Acura.
Car runs a little better but still wants to die when coming to a stop. Not throwing codes any more. Pulled the plugs and cylinders 1&4 are running lean, 2&3 are normal to slightly rich. Fuel pressure while running is good, around 43 PSI.
Not sure where to look next: fuel injectors/fuel rail?
Cap, rotor, ignitor, coil, spark plugs and wires are all lest than 6 months old. Also has new FITV, IAC valve, TPS is good.
Modified by delSolLS at 10:45 PM 7/5/2003
Old Jul 7, 2003 | 04:35 AM
delSolLS's Avatar
Default Re: Help with fuel system problem (delSolLS
Anybody have an idea where to start?
akinas-crx
Engine Management and Tuning
Nov 13, 2011 06:52 PM
JDM_SOHC
Nov 7, 2008 06:05 PM
01itr320
Jul 26, 2004 08:20 AM
asiansgoweeee
Jul 14, 2004 08:26 AM
delSolLS
Jul 8, 2003 11:03 AM
