HELP!! Excessuve Crankcase PRESSURE!!!!!!!
Old May 19, 2003 | 12:44 AM
joestud's Avatar
Default HELP!! Excessuve Crankcase PRESSURE!!!!!!!
My buddy's GSR Turbo'ed car is seeing excessive crankcase pressure. What causes it and how do we get rid of it. I was told that if it isn't fixed it will eventually lead to piston ring failure. It has been hondata tuned but about 3 weeks later it is idling abnormally and am seeing excessive oil from the breather filter on the valve cover. I was told an oil catch can will help. If so, how does it help? All your help and suggestions are much appreciated. Thanks guys.
Joe
Old May 19, 2003 | 01:29 AM
Westrock2000's Avatar
Default Re: HELP!! Excessuve Crankcase PRESSURE!!!!!!! (joestud)
Could be that you still have the original crankcase ventilation point which is on the intake pipe? If your using that point, then obviously the air inside the charge pipe is pressurised and is pressurising everything connected to it. Could reroute the vacuum hose to before the turbo, near the air filter.
If that applies to you hope it helps.
P.S. Yes a negative enviornment crankcase is very important to piston ring seal and lifespan.
Old May 19, 2003 | 10:52 AM
joestud's Avatar
Default Re: HELP!! Excessuve Crankcase PRESSURE!!!!!!! (Westrock2000)
Right now there isn't a crankcase ventilation point on the intake charge pipe. We just put a mini-filter on the valve cover nipple that used to run to the original crankcase ventilation point on the intake pipe.
Would rerouting the vacuum hose to the air filter pipe before the turbo, like what Westrock2000 said, be the key to eliminating my problem?
Thanks
Old May 19, 2003 | 02:24 PM
delslow94's Avatar
i suggest a catch can inline between the valvecover to a point between the filter and turbo. this will catch most of the oil and will also be able to pull all that excessive vapor from the head allowing it to run better.
Old May 19, 2003 | 02:56 PM
chevyalltheway's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joestud &raquo;</TD></TR><TR><TD CLASS="quote">I was told that if it isn't fixed it will eventually lead to piston ring failure.
Joe</TD></TR></TABLE>
sounds like thats already happened.
Old May 19, 2003 | 03:27 PM
Chiovnidca's Avatar
Have you checked the PCV valve? It could be leaking.
Old May 22, 2003 | 12:34 PM
joestud's Avatar
Default Re: HELP!! Excessuve Crankcase PRESSURE!!!!!!! (chevyalltheway)
Thanks for the advice guys. Anybody else have advice they want to add?
Baserloks
13
May 29, 2009 11:04 PM
poland accord
Aug 7, 2008 07:45 PM
kriptik
Jan 11, 2005 12:35 PM
zojirushi
Dec 15, 2001 12:37 AM
