HELP ELECTRICAL PROBLEM.....
Old Nov 20, 2004 | 02:18 PM
Mr HYDE's Avatar
Default HELP ELECTRICAL PROBLEM.....
LONG READ SORRY BUT PLEASE HELP (hope it all makes sense)
so pulled my motor undid the power wire to the starter. I let it go not remembering i never undid the battery and ZAP, and friend then took the wire and it slipp and touched metal again once again ZAP. So i undid the battery DUH to stop this, took the battery out and put it aside well i went to put the battery in forgetting once again i put the start wire on a bolt, put the power wire on and ZAP again **** i did it again, well i undid the power quickly and then i started walking away ZAP the power slid over. at this point the power grounded liek 4 times. so i then got it all set to test power in the car, and i looked at the fuses. The condensor fan was the only poped fuses under the hood and there was none under the dash, so i went ot turn the car on not start and my main relay was clicking crazy, (i think it was the main relay) and i had all power tho but no dash and climate control lights??????? what is the problem here anyone know. no poped fuses except the condensor fan, and all power works ecept dahs and climate control lights, and it sounds as if my main relay is clicking fast???????????? and i have a wire goin to a wire for my tach attached to a wrie goin in my main relay (acualty i did not do this the orginal owner had the tach this way) and when the clickign is goin on the light ont he tach is flickering.....
Old Nov 20, 2004 | 02:29 PM
drdisco69's Avatar
Default Re: HELP ELECTRICAL PROBLEM..... (Mr. HYDE)
Does the check engine light come on? I'd hate to say fried ecu, but...
Old Nov 20, 2004 | 02:32 PM
Mr HYDE's Avatar
Default Re: HELP ELECTRICAL PROBLEM..... (drdisco69)
ya the check engine light flickers with the light and clicking
Old Nov 20, 2004 | 02:35 PM
Mr HYDE's Avatar
also the fuel pump didnt prime when i went to start but not start jsut to hear if the fuel pump wout turn on
Old Nov 20, 2004 | 05:10 PM
Mr HYDE's Avatar
what no one can answer this ?
Old Nov 20, 2004 | 05:23 PM
AlDeVtec's Avatar
under ur hood u shure your 70a is not blown
Old Nov 20, 2004 | 07:15 PM
Mr HYDE's Avatar
Default Re: HELP ELECTRICAL PROBLEM..... (AlDeVtec)
not that i seen no
Old Nov 20, 2004 | 11:08 PM
fkncivic's Avatar
check every single fuse again then check ur main relay if that dont work then find a new ecu on ebay.
kyral
May 25, 2014 12:37 PM
GPC91
May 23, 2013 09:15 AM
JustCant5topMe
Mar 27, 2013 07:10 PM
CrazyModGSR
Audio / Security / Video
Oct 29, 2004 11:32 AM
