Help with ecu codes/erratic idle
Old Aug 18, 2002 | 09:17 AM
kikicamacho's Avatar
Default Help with ecu codes/erratic idle
Okay my Check Engine light did NOT come on.
But my car has had an erratic idle at every rm range for like a year.
I tried to see if the ecu would throw out a code so I jumped the little plug and got no codes, but the CEL light stayed on and the SRS light blinked on and off repeatedly. Is this normal?
This idle problem isn't that big a deal to me, but I think it may be costing me gas mileage. With the AC on I can feel it the most, but it does it all the time. like I'll be going down the hwy (55mph) and it'll surge like 1 or 2 hundred rpms, then go back down. Nothing too bad. But at lower speeds (city driving) it's more noticeable and the car kind of lunges with the fluctuations. Anyone had any similar experiences?
Old Aug 18, 2002 | 12:14 PM
C-speed's Avatar
Default Re: Help with ecu codes/erratic idle (jcamacho)
Check your plugs and spark plug wires.
Old Aug 19, 2002 | 04:49 AM
Default Re: Help with ecu codes/erratic idle (G3-TEG)
Good sugguestion. I installed new NGK plugs about a month ago, and I've since checked them. They're good. However, I've just assumed that my Accel Thundersport wires are still good. They're 3 years old. I guess I'll replace them wih some NGK wires and see if the problem goes away. I don't see or hear a spark "escaping" but I guess it won't hurt to replace 3 year old wires.
Old Aug 19, 2002 | 09:45 AM
C-speed's Avatar
You may want to take a look at the cap and rotor too for any signs of wear.
jeebertsab
33
Sep 23, 2015 03:57 PM
Tester2k
Aug 22, 2014 05:33 PM
Skybow388
Sep 18, 2012 07:51 AM
671islander
Aug 29, 2009 04:27 PM
