Help - Dropped Plastic hose in Differential !
Old Sep 22, 2004 | 01:12 PM
panykus's Avatar
Default Help - Dropped Plastic hose in Differential !
I accidentally dropped a short (2" Long) plastic hose in the filler hole of my rear differential and could not fish it back out (I was replacing the Differential Fluid). What would you recommend I do? Do I have to dismantle the whole differential? I tried draining it but the hose did not come out. What would happen if I fill the diffential back up, drive around a little, then drain it to get the plastic pieces out? Metal gears vs. plastic hose - the metal should chew up the plastic. Just not sure how to get the plastic bits past the gears so they will drain out if I do this.... Any creative ideas? I'm sure I'm not the first person this has happened to...
Old Sep 22, 2004 | 01:15 PM
99_SH's Avatar
Default Re: Help - Dropped Plastic hose in Differential ! (panykus)
Just pop the rear differential cover off. Very simple...
Old Sep 22, 2004 | 01:28 PM
panykus's Avatar
Default Re: Help - Dropped Plastic hose in Differential ! (99_SH)
I did consider that, but there are about 8 bolts and I can't get to the bolts on the top. Seems like I would have to dissconnect the axles first then drop the diffential? when done just replace cover and tighten bolts? Do you know torque specs? No need to worry about tolerances because I did not touch them, right?
Old Sep 22, 2004 | 01:39 PM
99_SH's Avatar
Go purchase whatever tools you need to access the bolts out of reach. No torque specs, just tight enough. And no, no need to worry about tolerances...
oaklandwilly
Aug 2, 2009 09:45 AM
ForcedAccord
Apr 18, 2005 08:54 AM
boot machine 5000
May 21, 2003 02:16 PM
crxmadman
Mar 9, 2003 07:41 AM
sshaikh01
Jul 9, 2002 04:11 PM
