HELP Del SoL won't start up!!
Old Feb 10, 2004 | 09:22 AM
93blkdelsol's Avatar
Default HELP Del SoL won't start up!!
A few day ago I hit an Ice block and cracked the oil pan, oil light came on about 1 mile and then the engine died NO knocking or anything to that mattter.... had the oil pan fixed and refilled the oil, changed plugs, distrubotor is good... battery is carhged Changed oil pressure switch... Car sounds like it wants to kick over just won't Ran out of ideas what could be the problem.... ANyone have a clue???
Thanks
its and old d16 engine from a 89 CRX (blew up the orignal engine a few years back) and when i had the oil pan fixed I was told it was throwing a code 22....
Old Feb 10, 2004 | 09:31 AM
crxsirvtec's Avatar
Default Re: HELP Del SoL won't start up!! (93blkdelsol)
does it crank over??
did you reset the computer?? disconnect battery for 15 secs..
Old Feb 10, 2004 | 10:21 AM
Default Re: HELP Del SoL won't start up!! (crxsirvtec)
It cranks but doesn;t kick over... and yeah i up did the battery for like an hour yesterday and still same thing cranking but not kicking over.. i just unpluged the ECU and hope that will work... but doubt it
Old Feb 12, 2004 | 05:56 AM
I reset the ECU and still not kicking over... Could it be a sensor or wiring somewhere?? ANy ideas... me and everyone I know can;t think of anything else...
Old Feb 12, 2004 | 06:11 AM
wickedEFguy's Avatar
check main relay and ignition fuse
Old Feb 12, 2004 | 04:02 PM
Found out the problem yall the rings are shot and I'm getting no compression... so the engine is shot i've been told so time to start thinking about a swap.. Thinking h22.... or b16a
BuddhistPriest87
Honda Civic (2006 - 2015)
Feb 10, 2012 02:40 PM
slacker6
Aug 31, 2010 01:33 PM
techsynthesis
Jan 13, 2008 09:45 PM
Tad
Jun 25, 2005 08:56 PM
lke2drvgsr
Jan 3, 2004 12:12 AM
