Help! Crazy coolant problem
Old Feb 20, 2010 | 07:25 AM
EGunit's Avatar
Icon3 Help! Crazy coolant problem
I just bought a 1996 Civic EX that was supposedly overheating. After getting it home and starting it up we came to find that when you crank the engine over, as soon as it fires it blows a huge blast of coolant out of the radiator. It was discovered that the radiator cap was bad, but even after replacing the radiator and flushing the system this problem still persisted.
It also came about that instead of the Y8 I was expecting, it was a D15B7/Y8 headed mini me. We confirmed the routing of the hoses, replaced the thermostat and I'll be damned if it still doesn't Ol' Faithful out the filler neck every time it fires, as well as when you bump the throttle at idle. Does anybody have anything to point me in the right direction?
Old Feb 20, 2010 | 07:47 AM
tofast4uh22's Avatar
Default Re: Help! Crazy coolant problem
pressure in the cooling system. mean bad head gasket.
Old Feb 20, 2010 | 08:00 AM
EGunit's Avatar
There's no coolant in the oil or oil in the coolant. When just idling with the cap off it doesn't blow it out. The coolant flows just fine watchin through the filler neck.
Old Feb 20, 2010 | 08:12 AM
fcm's Avatar
fcm
Old Fart
Ditto that^^^.
HG is blown, [or possibly installed improperly or wrong HG] between a cylinder and the coolant system. 94
Old Feb 21, 2010 | 05:51 AM
EGunit's Avatar
it appears as if you guys were correct. took the head off and it looked like a bear took a bite out of the area around cyl 1 and 4 right next to the intake valves by a coolant passage. hopefully this is all that it needs. thanks for the bump in the right direction, that was the only course of action not taken yet.
redrix
Jun 5, 2014 12:38 PM
alvinahmed
Sep 16, 2012 09:32 AM
soulo
Jun 8, 2008 10:28 AM
b00sted4dr
Oct 11, 2006 11:35 AM
mickey513
Dec 20, 2004 02:22 AM
