Help! C.E.L. dim all other lights normal
Old May 21, 2011 | 08:21 PM
dev203d's Avatar
Icon2 Help! C.E.L. dim all other lights normal
Ok I searched google the best I can, and HT doesn't even have an answer for this, I saw some forums with no right answer, so lets see is someone here can solve this. My friends 99si, swapped to a fully built GSR and ran on Hondata S300 off a P28 on a jumper harness down to OBD1 won't start. The engine cranks as much as you want but it won't start. When you turn the key to on position check engine light comes on but is very dim, all other lights are normal brightness and everything else works fine. IT IS NOT an alternator issue or a battery issue but I do think it's a Electrical issue. There is an odd flickering noise from the main relay but we changed it and no luck. The ECU that normally has the green light from the USB port flickers red and green rapidly, then settles on red. We changed the ignition coil and we are getting spark but I don't think we have fuel (didn't have any starter fluid or voltage meters to test this) if anyone can help thanks a lot! Any input is handy but remember it is not the battery, or the alternator!
Old May 22, 2011 | 06:40 AM
99blackcivicSi's Avatar
Default Re: Help! C.E.L. dim all other lights normal
grounds? specifically G101
Old May 22, 2011 | 08:18 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^, most likely a grounding issue.
Question, when you turn on the ign. to run,[and CEL comes on dim] can ypou hear the fuel pump priming, does CEL go out after a few sec.?
If not, drop the PGM-FI Main Relay and check it's ground, [black lead]. 94
Old May 22, 2011 | 08:07 PM
dev203d's Avatar
Thanks guys lemme check it out, I'll give u more info when I try tmrrw.
Old May 23, 2011 | 08:49 PM
lazyS2k's Avatar
hmm you sure you have everything plugged up correctly?
Old May 30, 2011 | 07:44 PM
dev203d's Avatar
Turned out to be the alternator belt, hmm weird.
Old Apr 4, 2014 | 06:21 PM
Kt18777's Avatar
How did you know it was the alternator belt?
cali.newguy
Sep 12, 2017 10:44 AM
Chiingy
20
Mar 26, 2013 08:01 PM
dtran002
Dec 5, 2012 09:29 AM
[JDM]noob
Dec 7, 2009 07:20 AM
HondaHemi
Dec 6, 2005 10:10 PM
