HELP bent valves HELP
Old Sep 12, 2005 | 03:57 PM
Boosteddc2gsr's Avatar
Default HELP bent valves HELP
i did a compression test on my gsr turbo and it went 135 135 90 135 i miss shifted from 3rd to 2nd any ideas on what could be the problem besides the valves.
STOCK MOTOR
Old Sep 12, 2005 | 05:54 PM
Bigorange's Avatar
Default Re: HELP bent valves HELP (Boosteddc2gsr)
now its time for a leak down test. usually when that happens your motor rpms shoot up through the roof depend ing on at what rpm you misshifted, sometimes causing more damage than just valves... my friend was racing his supra and did the same thing you did, now he has a hole through his block
Old Sep 12, 2005 | 07:03 PM
HEAD's Avatar
Default Re: HELP bent valves HELP (Bigorange)
could have broke some guides also, maybe valve touched a seat, there is alot to go wrong.
Old Sep 12, 2005 | 07:25 PM
im in the process of pulling the head what are some of the signs when guides are broken, and the seat touched
Old Sep 12, 2005 | 07:27 PM
rev-speed's Avatar
make sure the belt didn t jump before u condem anything
Old Sep 13, 2005 | 07:17 PM
the Belt is perfect so im hoping its only the valves
Old Sep 13, 2005 | 08:03 PM
rev-speed's Avatar
time to pull the head and face the nightmare
twentyhurtz
Sep 15, 2009 10:38 AM
zccrx
Nov 12, 2008 07:26 AM
loc_yaj
Apr 12, 2008 06:40 PM
chivid
Jun 9, 2006 07:46 PM
