help asap. Axle stop ring removal.
Old Sep 17, 2004 | 04:11 PM
huyvu90's Avatar
Default help asap. Axle stop ring removal.
How the heck doyou removal the stop ring inside the cv joint? It is so hard to pry.
I need a trick quick
Old Sep 17, 2004 | 06:34 PM
huyvu90's Avatar
Default Re: help asap. Axle stop ring removal. (huyvu90)
I guess nobody dissemble cv anyone. I'l just get the damn special pliers.
The outter joint was a bitch. How the heck am I going to get all that grease out?
Is dipping it overnight in simple green gonna get all the grease out?
And another thing, I fogot to mark the relationship between the tripod and the shaft and which bearing belongs to which shaft on the tripod. Is it really necessary?
Old Sep 17, 2004 | 07:38 PM
acurasolution's Avatar
There are 3 c-clips on an axle, two are easy, but one that holding the inner tripod is kinda tricky, i use a flat head snapring plier.
But using two pocket screwdrivers will do, just need some persistance that's all.
If you don't have "part washer" solution, then just toss the damn joint into the sink
filled with soap and water.
Old Sep 17, 2004 | 08:33 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by huyvu90 &raquo;</TD></TR><TR><TD CLASS="quote">
And another thing, I fogot to mark the relationship between the tripod and the shaft and which bearing belongs to which shaft on the tripod. Is it really necessary?</TD></TR></TABLE>
if you have a weird vibration, you know what the problem was!
calishowa
Suspension & Brakes
Jul 23, 2008 05:02 PM
K-Spec
Jun 14, 2005 02:09 PM
turbox
Apr 13, 2005 05:46 PM
killa_lude
Jul 22, 2004 07:39 PM
Bense
May 30, 2004 04:19 PM
