help with 96 hatch w/ stripped steering wheel stud/post
hey guys, i have a 96 hb and the steering wheel post/stud is stripped out. its the stud that holds on the steering behind the airbag with the 19mm bolt holding it on. so its pretty important,lol. my question is- can the stud/post be unbolted from the steering column and replaced? and whats the proper name for it? thanks in advance if anyone knows.
I think you need to replace the whole column, I doubt you can replace just the "stud". I could be wrong though.
Is it just the threads that are stripped? If so have you tried to fix them with a die?
thanks for the diagram. i think it might be to messed up to use the dye, but im gonna go pick up the whole set and give it a try. i figured that the whole piece would need replaced.
MyNameIsAlex
May 6, 2010 10:56 AM
jdmhatchek
Jun 3, 2005 12:06 PM
