HELP!!!
Cluster? You are going to have to provide more information on this. Did you purchase the car in pieces? Is something not working? Did you just find these connectors and want to know what they are for?
Well I got the car from some who bought it in pieces all the cluster plugs are in as for the climate control there in also ...thing that's not working is the fuel pump won't prime...you can prime the pump by jumping it and it still won't fire
This is on the drivers side (left hand side)? Under the dash? Are there plugs on the fuse box that are missing connectors? Those don't look like they are for the fuel relay at all. I'm at a loss.
no its in the center with the radio harness...everything in the fuse box is plugged in...the guy had a wire jumped to the main relay to bypass it for some odd reason....and ive put three engine harnesses in this car thinking they were bad.....maybe i should find a dash harness and see what happens...
SiR-G DC
Aug 20, 2009 08:04 AM
