HELP
Old Apr 15, 2012 | 02:15 PM
CGcivicGSR's Avatar
Default HELP
i have a 99 civic coupe with a 98 GSR swap in it i have a CEL on i replaced the sensors that need to be replaced but the code for the primary heated o2 sensor sensor 1 is still poping up and the code for the IACV valve and im running a 2000 SI B16 ECU just wondering if there is anything i can do because in trying to get an inspection sticker
Old Apr 15, 2012 | 04:06 PM
hybridmiklo's Avatar
Default Re: HELP
For the o2 sensor you need to make sure that there is voltage for the heater circuit going to the sensor. Start at the fuse.
Same for the iacv. Check to make sure it gets voltage at the plug. THen check to make sure there is ground.
Old Apr 16, 2012 | 06:05 AM
CGcivicGSR's Avatar
Default Re: HELP
thanks i will try that
crx2hatch
Feb 10, 2011 06:30 AM
crx-b18c
Apr 10, 2009 05:42 AM
omil2374
Oct 17, 2006 12:30 PM
BeavisB16
Apr 29, 2005 03:57 PM
Lewie
Jun 29, 2004 09:11 AM
