help
i have a b18b1 i compression tested it today its 170psi on all 4 cylinder is that ok, also my friend is rebuilding his gsr and bought rod berings and main berings brand new in box off kid on craigslist, when we looked up part number it said it was for ls, is there a difference between gsr and ls bottom end rebuild kits
well first off, your title is generic and most will not respond to that kind of lameness. second since you want to be a childish dick because noone respondrd to you, figure out your own bearing issue. its not that hard. if you can look up a part number for one part then Im sure you can do it for another
ejeffone
Engine Machining & Assembly
Jun 4, 2016 03:44 AM
