Heater Core Replacement
Old Nov 12, 2002 | 08:36 PM
EFing8's Avatar
Default Heater Core Replacement
anyone ever replace their heater core? My car is throwing NO heat at all and this is canada we are talking about. heat is WAY more important than any A/C.
This is a CRX btw.
How long can i expect to spend on this job? It looks like a big one by the looks of the manual.
It is 10 degree's bellow 0 celcius. I AM FREEZING TO DEATH.
Old Nov 12, 2002 | 09:02 PM
b19coupe's Avatar
Default Re: Heater Core Replacement (CND_CRX)
Make damn sure that your heater core is the problem before you tackle this job! The dash has to come out. Check your heater control valve-it's an inline valve near the firewall on the engine side. With the car warmed up to normal operating temperature, feel both sides of the valve. The hoses should be warm on both sides with the valve open. Have someone move the temperature control lever while you watch the valve: does the cable move the valve? The only time I have ever had to replace heater cores (twice) was due to leaking. good luck.
Old Nov 13, 2002 | 03:48 AM
PnX-R's Avatar
One of the guys at the shop said that for a 90 Civic, the Heater Core job takes roughly around 6 hours..
Old Nov 13, 2002 | 02:02 PM
EFing8's Avatar
Default Re: Heater Core Replacement (PnX-R)
oh lord I hope it is not the heater core. I tried taking the one off my parts car and i gave up after 1 hour.
Old Nov 13, 2002 | 03:04 PM
boosting's Avatar
cost me 400 to replace my heater core last year. that including parts and labor, BTW you know its your heater core when it starts spitting coolant on your feet...
Old Nov 13, 2002 | 03:40 PM
poison's Avatar
Default Re: Heater Core Replacement (boosting)
I would check to make sure that the heater valve to the coolant line is open.
have someone adjust the hot/cold control on the dash and look at the firewall towards the center you will see 2 coolant lines going into the firewall. look to see if they are opening or closing.
I would suggest taking it to a shop or seeing if water will flow thru the heater core inside a shop so you won't freeze outside. I'm not sure of weather over there. I hope it helps though
good luck
thewrai6th
Mar 10, 2016 04:24 PM
Shaw14
Dec 21, 2009 12:30 PM
fallmartin
Dec 2, 2008 05:01 PM
crxhoutx
May 4, 2004 07:00 PM
zgrimes
Oct 18, 2001 05:36 PM
