Heated 4-WIRE O2 Sensor problem...please read
Old Jan 8, 2003 | 07:36 PM
Projectg2i's Avatar
Default Heated 4-WIRE O2 Sensor problem...please read
I have a chipped P28 running my b16. Ever since I started using this computer, I no longer have a working O2 until I've done some heavy load driving to warm it up. I need to know if ANYONE knows which of the 4 wires deal with heating the sensor. I can't tune or anything until I get this sensor online with this ecu.
Old Jan 8, 2003 | 07:44 PM
tinkerbell's Avatar
Default Re: Heated 4-WIRE O2 Sensor problem...please read (Projectg2i)
teh two black ones - one is earth and one needs 12v from ignition
at least i think this is right.
try using the search function in hte achived posts.
teh answer is there for SURE!
t..
Old Jan 8, 2003 | 07:50 PM
tominos's Avatar
http://www.miata.net/hakuna/0004/aindex.htm try that post. for a miata but same thing.
Old Jan 8, 2003 | 07:55 PM
Desslok's Avatar
Default Re: Heated 4-WIRE O2 Sensor problem...please read (tinkerbell)
Old Jan 8, 2003 | 08:01 PM
Projectg2i's Avatar
Just checked the miata site and I believe that is the same O2 sensor. Two white, one black and one gray. The black should be signal, one white and the gray are seperate grounds and the other white is 12volt source. I only write this because I was just told the black is ground.
Old Jan 8, 2003 | 08:06 PM
tinkerbell's Avatar
dude, black is ground on a honda.
you need to do a SEARCH on "4 wire sensor"
t..
Old Jan 8, 2003 | 08:25 PM
Projectg2i's Avatar
OK, lets get simple.
I have a Heated 4-Wire Bosch sensor. It works fine on a stock PR4 LS integra ecu. Switched to a chipped P28 for a B16, and now I have a heating problem. I understand that black is probably ground. Thats wonderfull. The problem is that the archive and everything else refers to a two black, one white and one gray wire sensor. I DON'T have this. Its One black, One Gray and two white. You say the Black is ground but http://www.miata.net/hakuna/0004/h0007.htm shows my sensor with black as sensor output. I'm not trying to argue. I'm p*ssed because this has been a big problem for a long time and I just want it solved.
Old Jan 8, 2003 | 08:26 PM
tinkerbell's Avatar
call Bosch dude
t..
Old Jan 8, 2003 | 08:27 PM
Projectg2i's Avatar
Might as well. Oh, well.
Achenar
18
Mar 19, 2020 06:58 AM
mruneek
Jan 12, 2011 10:01 AM
civic_driver
Feb 23, 2006 09:24 AM
93FastLs
May 9, 2005 03:26 PM
