headers glowing bright ! wtf???
Old Feb 4, 2005 | 10:54 AM
  #26
HBoy's Avatar
Default Re: headers glowing bright red! wtf??? (pdotjones)
Well if that all straight, how is your valve lash? When you installed the new head did it have cams or did you use them from a different head? If you don't have the right clearance there it might be holding your valves open just a tiny bit all the time.
Old Feb 4, 2005 | 11:40 AM
  #27
pdotjones's Avatar
Default Re: headers glowing bright red! wtf??? (HBoy)
i used the cams and cam gears from my old head. i did check the valve lash, but i have doubt that i even did it correctly.
Old Feb 4, 2005 | 11:49 AM
  #28
HBoy's Avatar
If the cam timing is correct, set it to tdc and check the clearance on the exhaust valves. Should be able to get at least a .006 feller gauge in there.
Old Feb 4, 2005 | 02:06 PM
  #29
NJIN BUILDR's Avatar
Its possible that bent an exhaust valve or two when the cam timing was off.This would cause the engine to burn some of the mixture down the pipes.The same thing would happen if the lash was zero or less(holding ex valve open).I assume you set the initial ignition timing (usually 16 deg.).
Glenn
Old Feb 6, 2005 | 11:20 PM
  #30
pdotjones's Avatar
Default Re: headers glowing bright red! wtf??? (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">Its possible that bent an exhaust valve or two when the cam timing was off.This would cause the engine to burn some of the mixture down the pipes.The same thing would happen if the lash was zero or less(holding ex valve open).I assume you set the initial ignition timing (usually 16 deg.).
Glenn</TD></TR></TABLE>
besides taking the head apart, is there any way to check and see if the valves are in fact bent? that'll suck if i have to, seeing as how i just put the damn thing on.....
Old Feb 7, 2005 | 04:45 AM
  #31
Do a compression test.If its much less than around 160# you probably have a bent valve or the cams out off time.
Glenn
Old Feb 7, 2005 | 05:43 AM
  #32
everlasting1832's Avatar
Its definetely overheating. I would check your whole exhaust setup. Maybe the muffler or catalic coverter or Resonator might have some build up in it. Also is your engine fan running when its red? If it gets that hot under there Im pretty sure the fan would turn on. After turning red, did your oxygen sensor get messed up?
Old Feb 7, 2005 | 09:06 AM
  #33
pdotjones's Avatar
Default Re: headers glowing bright red! wtf??? (everlasting1832)
i don't have a cat, and ever since i put on my headers and had the exhaust done, i didn't have an o2 sensor on it...as far as the engine fan, i didn't or haven't seen it come on when the was running...
Old Feb 7, 2005 | 09:31 AM
  #34
FalkenSiR's Avatar
You are definately running rich, or like someone said
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">Usually its because of rich fuel and/or retarded ignition timing.If it was a cold start then it was rich to begin with.Did it pull a code.If something was disconnected the ecu might be pulling timing or enriching the fuel mixture.
I've seen this on many turbo cars.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by everlasting1832 &raquo;</TD></TR><TR><TD CLASS="quote">Its definetely overheating. I would check your whole exhaust setup. Maybe the muffler or catalic coverter or Resonator might have some build up in it. Also is your engine fan running when its red? If it gets that hot under there Im pretty sure the fan would turn on. After turning red, did your oxygen sensor get messed up?</TD></TR></TABLE>
Learn how to read
Old Feb 7, 2005 | 09:55 AM
  #35
pdotjones's Avatar
Default Re: headers glowing bright red! wtf??? (fast88std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">
Learn how to read</TD></TR></TABLE>
explain...
Old Feb 7, 2005 | 06:43 PM
  #36
EF9_R_Killa's Avatar
check to see if a code is being thrown since your not running and 02 sensor, Take off header and double check that theres nothing clogged, finally check that ignition timing is correct, even if cams and crank are aligned the ignition timing can be far off....
Old Feb 7, 2005 | 06:49 PM
  #37
pdotjones's Avatar
Default Re: (EF9_R_Killa)
this maybe a dumb question...how do you check the ignition timing? i never had to do it before, let alone remember reading it in a super street or something...
Old Feb 8, 2005 | 03:34 AM
  #38
Yusuke's Avatar
Default Re: (pdotjones)
You need to borrow or buy an ignition timing light http://www.sears.com/sr/javasr...=TOOL
It's probably one of the least expensive ones available and works great
Old Feb 8, 2005 | 04:02 PM
  #39
thatbluecrx's Avatar
Default Re: (Yusuke)
wow do they come like that out of the box???
nice pics sorry i have no answers but that glow is awesome!
Old Feb 8, 2005 | 06:13 PM
  #40
pdotjones's Avatar
Default Re: (thatbluecrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thatbluecrx &raquo;</TD></TR><TR><TD CLASS="quote">wow do they come like that out of the box???
nice pics sorry i have no answers but that glow is awesome!</TD></TR></TABLE>
bought them used....at a great price. seems now to be the red light special....
Old Feb 8, 2005 | 06:15 PM
  #41
beaterdriver's Avatar
when i had a dsm, my manifold started glowing while driving, i kept beatin on it (didnt care) and i burnt a valve, i was running too lean. but it was the 3rd most awesome thing i have ever seen tho
imo, glowing header = lean
Old Feb 8, 2005 | 06:24 PM
  #42
pdotjones's Avatar
Default Re: (beaterdriver)
was your dsm turbo, or na? i can imagine headers/manifold like that on a turbo charged car, but not na...
Old Feb 8, 2005 | 07:28 PM
  #43
slugzed's Avatar
u are running too lean.....same thing happen to me..
Old Feb 8, 2005 | 07:35 PM
  #44
pdotjones's Avatar
Default Re: (geezer_o6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geezer_o6 &raquo;</TD></TR><TR><TD CLASS="quote">u are running too lean.....same thing happen to me..</TD></TR></TABLE>
what was your end result? what did you do to correct it?
Old Feb 8, 2005 | 11:07 PM
  #45
ek9poorR's Avatar
your running lean big time....check your 02 sensors....its probably not plugged in all the way ...
my header did the same thing when i put a p28 ecu stock none chip on my gsr swap, my header was red as fawk!!
Old Feb 9, 2005 | 12:16 AM
  #46
pdotjones's Avatar
Default Re: headers glowing bright red! wtf??? (ek9poorR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9poorR &raquo;</TD></TR><TR><TD CLASS="quote">your running lean big time....check your 02 sensors....its probably not plugged in all the way ...
my header did the same thing when i put a p28 ecu stock none chip on my gsr swap, my header was red as fawk!! </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdotjones &raquo;</TD></TR><TR><TD CLASS="quote">
what was your end result? what did you do to correct it?</TD></TR></TABLE>
Old Feb 9, 2005 | 01:18 AM
  #47
1993sir05's Avatar
Default Re: headers glowing bright red! wtf??? (Quick4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quick4 &raquo;</TD></TR><TR><TD CLASS="quote">I installed a K&N and a slipon Exhaust onto my R6 and my mechanic showed me my header after running it for a bit, and it was glowing. He said the Bike was flowing a lot more air now and the stock computer couldn't compensate for the extra air. Which in turn makes it run lean and that means much hotter exhaust than normal. Do you have a FPR? that might help.</TD></TR></TABLE>
dont go to this mechanic anymore, he is taking full advantage of you whether you want to believe me or not.
and there is something seriously wrong with the headers glowing red like that.
good luck
Old Feb 9, 2005 | 04:08 AM
  #48
GDM Z28's Avatar
Default Re: headers glowing bright red! wtf??? (1993sir05)
do u have a fuel pressure guage? whats your fuel pressure set at? do u have a FPR? turn the pressure up..maybe your filter is clogged?...
Old Feb 9, 2005 | 05:24 AM
  #49
-RedneckDave-'s Avatar
Working
Default Re: headers glowing bright red! wtf??? (civicflnum1)
Looks like a lean running motor. I would up the fpr if you have one. Check the fuel filter as well.
Old Feb 9, 2005 | 01:12 PM
  #50
pdotjones's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflnum1 &raquo;</TD></TR><TR><TD CLASS="quote">do u have a fuel pressure guage? whats your fuel pressure set at? do u have a FPR? turn the pressure up..maybe your filter is clogged?...</TD></TR></TABLE>
well i do now. my fuel pressure is at 40 when at idle. and i went ahead and changed the fuel filter. i tried to check the timing with the gun, but the gun didn't seem to work, unless i used it wrong....
