header install?!
Old May 27, 2002 | 07:22 PM
EFing8's Avatar
Default header install?!
I ordered a DC ceramic header (GSR 4-2-1) for my LS/vtec setup. What do I do about the o2 sensors!?
Old May 27, 2002 | 08:19 PM
Kamin's Avatar
Default Re: header install?! (CND_CRX)
what do you mean?
you just screw it in like the stock header
im using a dc and it works fine.
Old May 27, 2002 | 08:41 PM
Tweakmeister's Avatar
the 02 sensor has a plastic clip that can be unhooked. When you pull the old header leave the 02 sensor in and then unbolt it once everything is out. Snap-On makes a special socket for it but you really only need a wrench.
Old May 28, 2002 | 05:41 PM
EFing8's Avatar
There are 2 o2 sensors on when running a PR3 ecu. The DC header only has a spot for 1! Where does the other one go?>
Old May 28, 2002 | 07:09 PM
sivik2nr's Avatar
in the catalytic converter prolly.......
atmosphere
Jan 21, 2006 12:36 AM
jweezy225
Nov 1, 2004 02:44 AM
Audio28
Feb 26, 2003 07:47 PM
Audio28
Feb 26, 2003 03:05 PM
ITR#97-0039
Jan 4, 2002 09:21 PM
