head gasket replacement (remove cams/vlaves ????)
Old Jul 26, 2006 | 05:22 PM
B18C-Hatch's Avatar
New User
Default head gasket replacement (remove cams/vlaves ????)
I have a fluidyne radiator with a stock fan and last night my car overheated when it was running in the parking lot. I toped off the coolant in the morning and now my car has white smoke and stutters at idle. I think i blew the head gasket but was wondering if it could be someing thing else. The oil and coolant did not seem to have mixed when i changed them but the oil and coolant were both old and dirty so it was hard to tell;
if it is the headgasket i have researched and found some DIY have me taking off the valves and cams is this really necessay? I have a JDM B18C with basic bolt ons (intake manifold,headers, exhaust...) and I am pretty confidant at replacing the head gasket if i don't have to play with the cams and valves.
so do i have to take off the cams & vlaves or just the timing belts with intake and ezhaust manifolds to reaplce the gasket?
thanks and any help or advice is appreciated
Old Jul 26, 2006 | 05:41 PM
civicstar's Avatar
Default Re: head gasket replacement (B18C-Hatch)
to replace the head, u need to take off the exhaust manifold, the cam caps, cams timing belt and intake manifold if u want but u can just unplug everything connected to the car to it. just take the 14 if its stock head bolts or a 13mm if its arp to the head studs and it should come right off, u dont have to take off the valves to change the head gasket. just make sure everything that connected to the head from the car is disconnected and it should be simple
Old Jul 26, 2006 | 06:53 PM
B18C-Hatch's Avatar
New User
Default Re: head gasket replacement (civicstar)
what about the actual cams, can i leave them in just remove the cam pulleys
Old Jul 26, 2006 | 11:05 PM
civicstar's Avatar
you have to remove the cams just leave the cam gears attached to the cams. you have to remove it because the head studs are right under the cam itself. the holes are where the head studs are
Old Jul 27, 2006 | 09:34 AM
B18C-Hatch's Avatar
New User
thanks for the input; will i have to take the vavles out and then do a valve adjustment?
i found this how-to but not sure if i have to all the steps
http://www.lightningmotorsport...I.htm
Old Jul 27, 2006 | 10:17 AM
civicstar's Avatar
as you see in the head above, all the valve and valve train are still intact when it was removed. removing all those is not nessecary to just remove the head from block. you remove the valves only if u wanna do a valve job, port and polish and so on. its just a waste of time if your just changing the head gasket
Old Jul 27, 2006 | 11:18 AM
Devilboiz's Avatar
good info and it is very useful
Old Jul 28, 2006 | 08:24 PM
B18C-Hatch's Avatar
New User
Old Jul 29, 2006 | 12:35 PM
ITRnorway's Avatar
take a comp check/leak down test before removing the head.
jdmkha
Nov 4, 2009 07:35 PM
cssrcr1
May 7, 2009 12:11 PM
Dee A Nine
Feb 6, 2009 05:58 AM
Methane2k2
Dec 18, 2004 06:27 PM
dvp95
Sep 9, 2003 09:26 PM
