Is this head done? Dropped valve......
Old Feb 28, 2006 | 06:40 PM
caspers_hatch's Avatar
Default Is this head done? Dropped valve......
Got this from itr head from a friend, he dropped the #1 valve. No damage to the top of the head.
I wanted to have it opened up for 83mm bore but didn't know if it was salvage-able (is that even a flippin word..ha.)
Thanks
Cylinder 1
Cylinder 2
Cylinder 3
Cylinder 4
Cyliner 4 close-up, worst one.
Old Feb 28, 2006 | 07:04 PM
b20vtech's Avatar
Default Re: Is this head done? Dropped valve...... (caspers_sfwd)
contact DonF here in ht and see what he says
Old Feb 28, 2006 | 07:52 PM
96b18c's Avatar
Default Re: Is this head done? Dropped valve...... (b20vtech)
seems like a pretty easy fix at a good machine shop. I used to work at a machine shop and the owner used to fix heads way worse than that. Good luck.
Old Feb 28, 2006 | 08:03 PM
dornon13's Avatar
Default Re: Is this head done? Dropped valve...... (96b18c)
i agree it is probably do-able but the question is it worth it
edit- I dont understand how it dropped #1 but #4 is jacked up
Old Feb 28, 2006 | 09:06 PM
Scott_Tucker's Avatar
The repair shouldn't be too difficult and any damaged areas can be built up with welding. The valve seats should then be replaced for safetys sake.
Old Feb 28, 2006 | 09:23 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Is this head done? Dropped valve...... (Scott_Tucker)
thats an easy fix. headgames can fix that.
Old Mar 1, 2006 | 12:31 AM
96b18c's Avatar
Default Re: Is this head done? Dropped valve...... (dornon13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dornon13 &raquo;</TD></TR><TR><TD CLASS="quote">
that's cause the chambers are open at the same time so if there are bits of the valve(s) bouncing around they will almost always end up messing up another cylinder. Same thing happened to me when I dropped a valve in my last head.
And yeah they will just replace the valves that were damaged, replace the valve seats, and with the machine work on the quench areas, the combustion chambers might have slightly different volumes, so a good machinist will compensate and try to even out all chambers depending on how deep the damage is. Or like someone else said they can always weld onto it.
Old Mar 1, 2006 | 06:17 AM
dornon13's Avatar
i still dont see it...the two cylinders are on opposite sides of the motor there only way in is the intake port or exhaust port right? just dont see how a bit of valve could travel that far .. i mean obviously it happend but i cant fathom it
Old Mar 1, 2006 | 06:38 AM
HEAD's Avatar
REAL easy to fix!
Old Mar 1, 2006 | 08:06 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dornon13 &raquo;</TD></TR><TR><TD CLASS="quote">i still dont see it...the two cylinders are on opposite sides of the motor there only way in is the intake port or exhaust port right? just dont see how a bit of valve could travel that far .. i mean obviously it happend but i cant fathom it</TD></TR></TABLE>
It wasn't a bit of the valve, it was the keeper. The valve is all intact still, just a little bent
Old Mar 1, 2006 | 08:07 AM
Default Re: Is this head done? Dropped valve...... (HEAD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HEAD &raquo;</TD></TR><TR><TD CLASS="quote">REAL easy to fix! </TD></TR></TABLE>
IM sent, need a quote and i will send it out to you guys asap.
JerseySiPOS
Jun 3, 2011 02:26 PM
Tyteg
May 8, 2007 09:53 AM
brodyl05
Mar 12, 2007 09:56 PM
SoCaLNaTIvE
Apr 24, 2005 09:21 AM
CPR
Aug 7, 2004 02:14 PM
