having problems with the tps sensor
Old Sep 11, 2003 | 09:32 AM
AllMoToRB18c's Avatar
Default having problems with the tps sensor
once a tps sensor is removed from the TB does it have to be re-calibrated?...and if so does anyone know the specs for it?...i know u have to use a volt meter to do it...but i dont know where to set it at...its for a 94 b18c1 motor....i hope u guys can help me out cuz i cant find it anywhere....thanks
Old Sep 11, 2003 | 09:51 AM
Default Re: having problems with the tps sensor (AllMoToRB18c)
i guess nobody knows
Old Sep 11, 2003 | 10:07 AM
IN VTEC's Avatar
You should at least check to see if it needs calibration, but it always does, so you might as well assume that you do have to re-calibrate it.
Pull the little grommet back on the TPS harness connector (harness side) on the red/blk wire (middle one), and insert the red probe of the voltmeter in there. Ground the black probe. Adjust the TPS as necessary while watching the voltmeter.
.45V to .50V volts, with the plate fully closed. I could never get the WOT voltage = 4.5V...it always comes out a little less than that, but that's nothing to worry about.
Old Sep 11, 2003 | 11:36 AM
Default Re: having problems with the tps sensor (IN VTEC)
thanks for ur help...im almost positive that it needs calibration cuz it was removed b4 and i heard that once its removed it has to be calibrated....maybe im wrong but the throttle feels a lil funny sometimes like it reacts slow..but thanks for ur help
GarrettChames
Feb 20, 2012 05:35 PM
jonezen1
Sep 3, 2007 05:41 PM
uber_nihilist
Jun 25, 2006 05:07 PM
rhemu1
Jan 6, 2006 05:39 AM
Mr.Death
Feb 6, 2005 02:30 PM
