Is having carbon build up in an engine a normal phenomenon?
Old Dec 6, 2017 | 05:23 PM
eddie7978's Avatar
Default Is having carbon build up in an engine a normal phenomenon?
i just bought a used jdm engine and there’s a lot of carbon build up in the intake manifold the exhaust ports.. the intake ports had a little and the spark plugs have some and the top of the pistons look dark as well..
is is this something i should be concerned with? the engine is all stock but do you think it’s running rich or something??
Old Dec 7, 2017 | 02:04 PM
b20ricepower's Avatar
Default re: Is having carbon build up in an engine a normal phenomenon?
it's probably normal. Could have a decent amount of miles on it. I've had engines look almost brand new and some not so much. Luck of the draw.
Old Dec 7, 2017 | 05:15 PM
eddie7978's Avatar
yea they said it had about 50k but who knows.. looks like it was running rich but i’m goin got do a leak down test
Old Dec 9, 2017 | 05:23 PM
eddie7978's Avatar
i’m doing a leak down test and some of the cylinders are reading high.. now the motor is cold and has some carbon deposits so idk how accurate it is.. i wish i knew for sure
Old Dec 11, 2017 | 09:55 AM
egsleepercivic's Avatar
Default Re: Is having carbon build up in an engine a normal phenomenon?
where did you get the motor from ?
Old Dec 14, 2017 | 08:14 PM
ChrisF23's Avatar
Perfectly normal, I would be worried if i didn't see any, because that usually means that the engine was cleaned up for hiding something worst (happened to me), just beware of oil!
Old Dec 17, 2017 | 03:05 PM
Bteggy89's Avatar
I agree with Chris, especially if one of the piston crowns is squeaky clean. Classic head gasket issue
s13hero
Dec 27, 2011 01:38 AM
EG type GTR
Jun 26, 2006 10:15 PM
gldndrgn14
Jun 20, 2005 04:01 AM
joeg26er
Feb 7, 2002 10:32 AM
joeg26er
Feb 3, 2002 10:20 PM
