To have the head milled or not?
I recently bought a D16Y7 head used, guy said it had 55,000mi on it, not sure how much of that is true but it looked pretty clean from what I saw. I'm looking around for a Y7 block to bolt it up to and was wondering if it would be worth getting the head milling or at least checked for warpage seeing as it's going onto a block that it was not specifically made for. Or am I just being paranoid and I need to shut up and bolt the head on?
Head should be resurfaced or at least check by a professional machine shop.
Don't skip out in a new oem gasket either.
I'd forget about the mill if you wanna raise compression do it the right way and swap pistons.
RSSEXtype-sizzle
Aug 12, 2012 09:46 PM
