Harness wire colors
Old Mar 15, 2011 | 01:23 PM
be18see1's Avatar
Default Harness wire colors
I'm working with a obd1 nonvtec harness from a 1993 Acura Integra. I rewrapped the whole thing with nylon sleeving and heat shrink tubing. However, the time from start to finish for this project was six months. I do have all of the wires into each coupler but I'm not sure which couplers are which (ie coolant temp, tps, MAP, etc etc).
So..
Does anyone have a harness diagram for the engine harness in this car? I have a copy of the "Electrical Wiring" from hondahookup.com but does not include the engine harness. I would imagine even any obd1 harness would be similar enough that I could figure out which couplers are which.
Old Mar 16, 2011 | 07:36 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Harness wire colors
haynes manual or ask www.hondata.com
label your plugs
Old Mar 16, 2011 | 08:12 AM
be18see1's Avatar
I've got most of them figured out. Now I just need to figure out exactly what the coupler I have left goes to. One wht-grn wire and one black wire.
Old Mar 18, 2011 | 06:13 AM
Blown90hatcH's Avatar
www.helminc.com
Old Mar 18, 2011 | 07:57 AM
be18see1's Avatar
I'm not spending all that money on a Helms manual to solve one tiny little problem.
Old Mar 18, 2011 | 02:29 PM
Yikes....that's a ton of cash for something you will never use again in the future....good call.
Old Mar 18, 2011 | 03:57 PM
be18see1's Avatar
Thanks for your help.
PS: I have a copy of the electrical section of the Helms manual for second gen Integras and I have yet to find the coupler in question.
Old Mar 19, 2011 | 03:38 PM
fcm's Avatar
fcm
Old Fart
White/green and black = "Engine Oil Temperature Switch". 94
Old Mar 20, 2011 | 06:27 AM
be18see1's Avatar
I just figured that one out last night. Now I have to figure out where that sensor is because I don't have any open sensors left. Thanks a lot!
Old Mar 20, 2011 | 06:42 AM
be18see1's Avatar
fcm:
Do you know the answers to any of these questions? I see you helping out with these questions all over g2ic!
It appears that the b16a does not have an oil temperature sensor. Is this sensor necessary? What does the output from this sensor control? Thanks in advance.
edit-I just did a little more research and found that the p72 ecu that I am using does not have an input for this sensor so I *think* I can run without it. However, I would still like to know its purpose.
Old Mar 20, 2011 | 07:20 AM
fcm's Avatar
fcm
Old Fart
The engine oil temp. sensor is used to turn on the rad fan on, [when ign. switch is off] if oil temp is up too high.
It is obviously not a necessary sensor as CDM G2s do not have them or even the "Radiator fan Control Module" that it connects to. 94
Old Mar 20, 2011 | 08:02 AM
be18see1's Avatar
Okay cool. The coolant switch should control the fan's normal operation, right? So the oil temp switch is essentially just a fail-safe and isn't typically controlling my cooling fan? I really appreciate your help.
Old Mar 20, 2011 | 04:06 PM
fcm's Avatar
fcm
Old Fart
I believe it has something to do with your emissions, your, [USDM] emissions standards are a lot stricter then ours.
The ECT switch will control the rad fan, just like it does on CDM G2s, [just not when ign. key is off] we just do not have the EOTS and RFCM, seems to me they are just two unneeded electronic parts that can and do fail.94
Old Mar 20, 2011 | 06:01 PM
be18see1's Avatar
Alright, I understand. Once again, thanks for your input.
10larryp
Mar 6, 2014 12:48 AM
Racermech
Jun 18, 2005 07:34 AM
Drake71400
Mar 25, 2003 04:48 AM
