Harmonic Balancer needed? LS/vtec
Old Jan 18, 2009 | 08:15 PM
Boostage's Avatar
Default Harmonic Balancer needed? LS/vtec
Is a ATI or fluidamner still needed with after market rods and pistons if the rev limit is no higher than 8500? I know Aftermarket internals changes the harmonic vibrations of an engine in upper rpms. but I dont know if the stock pulley will suffice for my rev limit.
Old Jan 19, 2009 | 02:26 PM
Boostage's Avatar
Default Re: Harmonic Balancer needed? LS/vtec
Alot of views and no answer, anyway for anyone who might find this topic in the future. it turns out Harmonic Vibrations are not a concern with aftermarket internals at 8500 rpms. the stock pulley provides enough dampening at that level.
Old Jan 19, 2009 | 02:45 PM
miguel329's Avatar
i was going looking into a ati but i will deff just save the cash.
Old Jan 19, 2009 | 05:35 PM
Padawan's Avatar
Darth ModerVader
The stock pulley will be fine. If anything, you should be more concerned with having your rotating assembly balanced.
Old Jan 19, 2009 | 05:49 PM
srmofo's Avatar
well what about above 8500, my stock balancer had a chip taking out of the outside pulley but it isnt being used so I just cut it off with the help of a brake lathe...now Im rebuilding the motor and I have alot of money into it and I dont want to risk future problems to save a little cash....
Old Jan 19, 2009 | 06:18 PM
Boostage's Avatar
Personally I feel if you have alot of money into it then getting a fluid or ati isnt anything much to secure your investment, the reason I started this thread is because despite aftermarket guts, my setup is pretty conservative and I wanted to be sure. I probably waont even rev past 8k.
Vspronk
Sep 9, 2015 02:02 PM
rudebwoy
Sep 18, 2009 09:05 AM
Boostage
Jan 16, 2009 08:07 AM
crumb
Oct 31, 2005 09:41 AM
