half ton setting on hoist for v6?
Old Sep 12, 2016 | 02:18 PM
fuzzysig's Avatar
Default half ton setting on hoist for v6?
I'm a bit suspicious on that half ton setting on the 2 ton engine hoist.
will that be ok to pull a 3.5L v6 block without transmission?
the jack says 8 ton limit the hoist itself is 2 ton (short arm)
.5 ton extended arm.
just seems a bit suspicious to me if they are actually rated at 1000lbs(half ton) or is like Chinese stereo equipment claiming 5000 watts
this type of hoist not same brand just same type
Old Sep 13, 2016 | 10:41 AM
fcm's Avatar
fcm
Old Fart
Default Re: half ton setting on hoist for v6?
As the Honda 3.5l engine complete without transmission only weighs in a 250lb I see no problem lifting it. 94
Tchsqb3
Feb 20, 2007 12:29 PM
tubby703
Oct 12, 2005 09:51 AM
