Half Shaft Question (Really Quick)
Old Mar 10, 2004 | 10:32 AM
Andres-eh2's Avatar
Default Half Shaft Question (Really Quick)
Im going to drop a b18a1 into my 93 CX. I know that i need to change to a hydro tranny if im not getting the conversion kit.
If i get any b-series hydro tranny, will i need to get another halfshaft or can i use the one i have from the b18a1???
TIA
Old Mar 10, 2004 | 06:02 PM
Andres-eh2's Avatar
nobody?
Old Mar 10, 2004 | 08:06 PM
quik1's Avatar
Default Re: (Andres-eh2)
They are the same.
Old Mar 11, 2004 | 05:21 AM
Andres-eh2's Avatar
anyone else?
Old Mar 12, 2004 | 03:37 AM
Andres-eh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andres-eh2 &raquo;</TD></TR><TR><TD CLASS="quote">anyone else?</TD></TR></TABLE>
Old Mar 14, 2004 | 07:20 PM
Andres-eh2's Avatar
can someone else please confirm this?
Old Mar 14, 2004 | 07:22 PM
Dan GSR's Avatar
Default Re: (quik1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik1 &raquo;</TD></TR><TR><TD CLASS="quote">They are the same.</TD></TR></TABLE>
Old Mar 14, 2004 | 09:00 PM
Sliced Beard's Avatar
Default Re: (Dan GSR)
either will work fine but you have to make shure that the tranny halfshaft seal (where the halfshaft inserts into the diff. there is a rubber seal)is the correct size otherwise you may have either an impossible time geting the halfshaft in or it will leak all of the fluid out of the tranny(don't ask how i know about the leaking part )
Old Mar 15, 2004 | 06:22 PM
Andres-eh2's Avatar
tks
Old Mar 15, 2004 | 06:24 PM
Andres-eh2's Avatar
Default Re: (dirtyd463)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 &raquo;</TD></TR><TR><TD CLASS="quote">either will work fine but you have to make shure that the tranny halfshaft seal (where the halfshaft inserts into the diff. there is a rubber seal)is the correct size otherwise you may have either an impossible time geting the halfshaft in or it will leak all of the fluid out of the tranny(don't ask how i know about the leaking part )</TD></TR></TABLE>
can you tell from this pic?
Old Mar 15, 2004 | 07:04 PM
i think it will work fine with a cable tranny
Old Mar 15, 2004 | 07:05 PM
but if you are going to use a hydro tranny you will have to go with a seal for a 90-93 integra
Old Mar 15, 2004 | 07:21 PM
Kataku2K3's Avatar
Okay first off, yes the halfshafts are interchangeable but you have to match the seal as dirtyd463 said. What axles are you running in your EH with this B18A tho? Personally I would just go with a hydro tranny as it will save you a lot of time and the hassle of dealing with the conversion (I've done it before and don't like it, besides cable trannies in general don't feel as nice and are older). You really need '94-2001 Integra, Del Sol DOHC VTEC, or '99-2000 Si axles and halfshaft (male halfshaft) for this swap whether you're dealing with a hydro or a cable tranny.
Old Mar 15, 2004 | 08:32 PM
Andres-eh2's Avatar
im going hydro no doubt about it.
blackblack
11
Dec 29, 2007 12:32 PM
89hatcher
Aug 7, 2007 07:19 PM
BlackHXCoupe
13
Apr 3, 2006 10:31 PM
RACEPAK
37
Apr 7, 2005 04:45 PM
HaUTSaauce
Jun 5, 2003 07:37 PM
